bergz22
- Lemont, IL USA
Hello, this is my first post, I'm sure this has been discussed many times, I don't mean to bring it up again but I was confused in doing some research. I am in the process of remodeling a basement that was finished previously. Here in my town we are under the 2005 NEC. In one corner of the basement there is a hidden door leading to a small room that houses the foundation sump pump, downstairs ejector pump, and back up battery and charger. On the other side, in a finished laundry room there is another sump just used to pump out washing machine water and from a utility sink.
This is what reads in my towns amended electrical code:
15.10.040 BRANCH CIRCUITS REQUIRED:
A. In addition to those branch circuits
required by the above adopted electrical code,
separate additional branch circuits shall be provided in a dwelling occupancy as required
below: (slightly edited for size)
9. Sump pump.
10. Sanitary ejector pump.
11. Central vacuum system.
B. A single receptacle shall be required for all cord and plug appliances and equipment required to have a dedicated circuit.
So do this mean I can use a separate circuit for each the house sump, ejector pump, and washer pump, with each being on its own simplex receptacle? I know a gfi would be wise but is it necessary to go above the code requirements? I would then need to put in a water level alarm, if I went gfi, considering a lot of people complain about them tripping constantly.
9. Sump pump.
