TacomaMike
Could someone help answer this question ?
I have a 3/4 HP 110VAC Sump Pump I am using in a damp vault. NEC tells me that I cannot have a plug on this sump pump, I must have it hardwired and a snap switch disconnect(because it is over 1/3 HP). The pump came with a plug even though it is a 3/4 HP, the mfg. tells me that it is a 7 amp motor even though it's a 3/4 HP and that cutting the plug off to hard wire it will void the warrenty. Seems like I cannot use this pump because NEC conflicts with the mfg..
My original plan was to plug it into a dedicated GFCI outlet !
