GerryB
- woodbridge, ct. USA
Is there or was there a code section allowing a "super neutral" to replace for example individual neutrals in a panel. I came across a panel recently that had been relocated to the front of the building. There was a ridgid conduit run from the old panel ie: j-box to the new. The hots were brought through to the breakers and the neutrals were all spliced to a #6 and that was the only neutral brought through. I did post about this before and thought there was a reply about the super neutral. Also I was thinking about gen-tran panels that only bring one neutral and ground back to the main panel. In that case I think a non-ferrous nipple makes it OK. Thanks in advance.
