Is SEU cable permitted for a supply side connection and the bond screw installed at the supply side disconnect and then 4 wire to the PV equipment or must the supply side PV conductors be 4 wire with an insulated neutral & EGC to the PV disconnect and no bond screw installed, or are both methods compliant?
