russ
- Burbank IL
Re: Support of wiring in drop ceiling
Caddy also makes a bright yellow clip that slides on to the ceiling grid for anchoring the bottom end of the independent wires installed for the conduit. You can't mistake these for anything, but for use of holding the conduit.What bugs me is that if you install an additional support wire, to use for the wiring method, you'll have to secure it at both ends, ie, the ceiling grid. How do you differentiate between a ceiling wire and a cable wire?
