Supports
They did spec pvc coated 👍
SS is difficult to source, expensive, and from what I’ve heard, difficult to work with. I have no experience with it however.
no. just thought stainless or pvc coated would make more sense because of the raceway type.
I would expect that the straps would be specified as PVC coated. Standard clamps will not fit correctly because of the increased outer diameter.
Note this type of installation requires additional labor, training, and special tools to prevent damage to the outer PVC protective surface. It is also expensive. Some specs require that the installer be certified by the PVC coated conduit manufacturer.
Thank you. So you're saying a two-piece strut clamp won't fit? Can't be.
Not properly, maybe if you changed the bolt to a longer one. But a PVC COATED clamp will fit properly and provide corrosion protection equal to the conduit.
-Hal
B-line regular rigid straps usually work for me. Sometimes just have the squeeze them a bit with pliers to get the nut started.
