zemingduan
- Philadelphia,PA
- Electrical Designer
The new code requires surge protection for the service for dwelling units. I am curious how do you implement this? For example we are using Square D (EZM series)/Eaton (3MM series) residential group metering with the meter stacks and main section for (60) apt units. The main section is 1600A 3ph with a main circuit breaker. The meter stacks are plugged into both sides of the main section. Is there a SPD can be installed at the main section of the residential meter bank? Or do you install individual SPD at the load center of each apt?
Thanks!
Thanks!
