Surge Protection RTU units
Scott C
I need to install surge protection for a customer who has had issues in the past with lighting causing damage to their two units. I am looking for a reliable cost effective way to do this. Also is there a A/C dissconnect switch with built in protection that will work for this? this is a one story strip mall.
Scott
Welcome to the forum.
Is the lightning hiting the units themselves?
If this is so, I do not believe there is much in the form of direct lightning TVSS/Surge protection for that type of situation... you would be wasting your customer's money in selling them a TVSS/Surge product that does not exist.
Maybe a lightning protection system... That is a better question for someone like Derek to answer.
Good Luck in finding an answer!!!
Scott define RTU please. Are you referring to a Remote Terminal Unit used for contro, telemetry and data? If so it takes more than just protecting the AC power. You have to go an extra step and protect all the I/O lines and have a common ground reference for all systems.
Rtu
Rtu
These are A/C Air conditioners. I was told that they were not hit directly although very little else has been affected by the surge.
HVAC techs are quick to blame odd electrical failures on lightning. You could do a perfect job protecting from the imagined surges, and their problems would persist. If it was me looking into their work, I'd want a little more detail of the exact problems they're experiencing. I would want to determine the components that are failing, compare that to the unit's schematic, and see if any other failure modes (besides lightning) would take out that part or parts.
It is not only HVAC techs that blame mysterious problems on lightening, surges, or "bad grounds".
To answer the original post, yes there a zillion TVSS mfrs out there that make protection for panelboards, which is what you would want to use for the RTU. Look around at Liebert and Current Technology for examples. But I also agree that more investigation would be a good idea.
Low voltage (brownout) conditions are often the culprit here so a TVSS isn't going to solve anything. In my experience I've found many cases of a commercial building that simply didn't have the service feed properly tightened - pretty bad news when it's the neutral.
Check it out and, if in doubt, contact your local power & light company to verify their ends are good.
