T
T.M.Haja Sahib
Guest
All panels have to have their ratings marked on the nameplate. Additional labels are required for series rated systems. Jim was talking about the rule in 110.24 in the 2011 code that requires service equipment, other than in dwelling units, be marked with the available fault current. Not the rating of the panel and its breakers, but the amount of current that the utility could supply into a fault.
Marking on the enclosure of disconnecting means including that of service equipment containing series connected breakers or fuses with maximum fault current level rating such as
CAUTION ? ENGINEERED SERIES COMBINATIONSYSTEM RATED _______ AMPERES. IDENTIFIED
REPLACEMENT COMPONENTS REQUIRED.
is mandatory for any occupancy (110.22).
