fisherelectric
- Northern Va
We're going to be hooking up a residential swim spa under the 2011 NEC. It will be outdoors in a ~20'x12' pit with block walls and concrete slab, so water level is at ground level. I intend to run #8 bond wire around perimeter of tub in the slab under the tub as well as around the perimeter of tub at ground level under wood decking (as well as any other metallic equipment). Just curious as to how others see this. Maybe under the decking is overkill.
