Swimming pool code
mjc
Hi guys ,
Wet-Niche Fixtures, Specifically 680.23(a)(3) Cant seem to locate where the NEC would require the entire 115v branch circuit to be supplied from a GFCI CB at the panel. The other choice is to GFI the fixture from the load side of a GFI recepticle. Is type of install acceptable? This seems to serve the same purpose but I have seen GFI recepts. go bad but still function as an outlet. :eek:
Thanks Mike
