Fulthrotl
~Autocorrect is My Worst Enema.~
- E
ok. service call to a residence.
pool with attached jacuzzi. both have pentair pool lights, 120 vac.
breaker is tripped. when reset, and lamps turned on with switch.
breaker trips. breaker is 20 amp.
GFCI does NOT trip.
i replace GFCI, just for drill. brand new leviton GFCI blank face,
after the light switch. test gfci downstream. it works correctly.
disconnect both lights at their respective junction boxes, and
reset the breaker, and turn the switch on. breaker holds.
gfci holds. premises wiring to box is good.
120 volts at the junction box.
i hook up the first pool light. it goes on, pulls 4 amps. lights up
fine. i disconnect it, and hook up the second pool light. it goes
on as well, pulls 4 amps. lights up fine.
i shut the switch off, hook both of them up, turn it on, breaker
holds for about 2-3 seconds, pulling 20 amps, and breaker trips.
GFCI does NOT trip. at all. ever.
any thoughts on this one?
randy
GFCI does NOT trip.
randy
