- Tennessee NEC:2017
- Semi-Retired Electrician
If you have a pool that has low voltage (12V) LED lights, and the lights have non-metallic flex liquid tight run from them to a transformer in an enclosure, how would you comply with 680.24(E) [2008]? How or what would you use for strain relief that would connect the liquid tight to the enclosure?
The lights have a cord with +/- conductors. The cord is what is in the liquid tight. The lights are not in a forming shell. I suppose you would call them a "through the wall" type light.
Would 680.24(E) even apply here?
