- Bremerton, Washington
I went to Mike Holts 2 hr grounfing and bonding seminar in Seattle. He and his staff have done a lot of testing and videos showing results of 120v to swimming pools, boat docks and ground rods.
the used a floating meter board to illustrate step potential and gradient.
Mike said
*Do not have 120v on a boat dock for outlets, lift, or lights.
* No 120v pool lights, use nonmetallic ladders, be very dilligent in bonding mesh around pool.
* be very cautious if called to ts stray voltage in a pool, best to turn off power and call experts, otherwise you could be liable.
he demonstrated how a energized ground rod, 120 v, at a heat pump or street light, with no egc, extends the voltage gradient and makes the installation less safe.
it was interesting and informatitive, i am not sure how the videos will be available.
He almost set the house on fire...energized the pool bond with 120v, current was returning via screen house, metal soffit, can lights and egc.
