The one in my kitchen does. Whether it disconnects all the power to the unit, I have no idea. But a lot of the dishwashers I've connected have the fancy digital controls, so my guess would be "no."Originally posted by volt102:
Peter, do the dishwashers that you normally see have the marked off unit switch,the one that says pots and pans, normal load, rinse only, etc.? if so, it could be code compliant, see my 1st post in this tread.
Jim
Are you talking about breaker locks to lock the breaker off, or to lock the breaker onas an emergency light circuit?Originally posted by infinity:
Chris,
We've used both GE and SQ D breaker locks and yes they're designed so that you can close the door on the panel.
It would be my guess that the NEC is talking about the type of lock that is mandated by OSHA rule 1910.147-Procedure for applying the Lock/TagOriginally posted by bradleyelectric:
Chris,
We're talking about a metal clip that gets installed on the CB before the panel cover is installed and remains there. I has a loop on it to allow someone to turn the breaker to the off position and install their own padlock. This is not the clip with the set screw that we use to lock a CB in the closed position usually seen on exit signs and emergency lighting. Also these aren't the temporary lockout devices made of plastic by Panduit etc., that allow for the temporary lock out of the breaker. The permanent type allows the panel door to operate as normal, meaning it can be closed with the lock out device in place.Are you talking about breaker locks to lock the breaker off, or to lock the breaker onas an emergency light circuit?
