Well, that's not exactly true. Both fuses and breakers are divided into classes where physical size is a parameter. To wit:jim dungar said:The NEC only lists the amp ratings of overcurrent devices, it does not care about their physical size.
You do know that those are the max ratings in each size, and there are others between, I take it. "Up to 30, up to 60, etc."In the US the fuse "cartridge" sizes are 30, 60, 100, 200, 400, 600A therefore the switch manufacturers make comparable sized switches.
To a large extent, greater currents resuire larger contact area between fuses and their holders, they make bigger sparks when they open, and it helps reduce the magnitude of overfusing.I have no knowledge as to why the US standardized on these cartridge sizes.
LarryFine said:Well, that's not exactly true. Both fuses and breakers are divided into classes where physical size is a parameter.
