- Tennessee NEC:2017
- Semi-Retired Electrician
Read post 5
Doesn't explain what the light is for, well to me it doesn't anyway.
Read post 5
This post does not seem to clearly define what is wanted.I have 3 seperate machines. Each machine can turn on the same light (hypothetical). Before any of the 3 machines can turn on the light, a control signal must first be sent to the "light".
So it is a 2 step operation. Control signal from any 1 of the 3 machines, and then another signal from any of the 3 machines to allow the light be illuminated to the individual machine. 1 light, 3 machines, 1 central control solenoid, 3 seperate supply solenoids (1 for each machine). All three machines can be illuminated from the single light source at the same time.
I would like to have the initial control switch located on each machine. I am getting tripped up a bit on how to get 3 seperate machines to access 1 solenoid. I worry about all three switches being on at the same time. It would probably be easiest to just have the control switch on 1 of the machines. The control voltage to the solenoid is 120V.
Any thoughts guys is appreciated. Thanks again.
"the light" seems to imply one light for the three machines, and the last sentence of the second paragraph says one light illuminates all three machines. Further the word "allow" seems to imply there is something else that may control the light. In other words, the the two said signals are only enablers. That is, the two signals are conditions to allow something else to control the light.Control signal from any 1 of the 3 machines, and then another signal from any of the 3 machines to allow the light be illuminated to the individual machine.
I believe this sentence means --- "The single light source" is used to illuminate all three machines.All three machines can be illuminated from the single light source at the same time.
That would probably work betterAmpacity less than OCPD? So I would be able to install two a #14 in parallel for a 1000A feeder circuit????
I'm thinking that should be equal or greater than.
139506-0801 EDT
Post 5This post does not seem to clearly define what is wanted.
What is an "initial control" switch?
What is or why is "a 2 step operation" needed?
What is a "control signal", what creates it?
What is "another signal"?
Then this sentence "the light" seems to imply one light for the three machines, and the last sentence of the second paragraph says one light illuminates all three machines. Further the word "allow" seems to imply there is something else that may control the light. In other words, the the two said signals are only enablers. That is, the two signals are conditions to allow something else to control the light.
Assuming "the single light source" is the light source for the three machines, then the question is "what is the logical description for the control of said light"?
I have previously assumed, because the statement of the goal is not clear, that this logic is "the said single light is on when any one or more machines are on". This assumption may not be correct based on whatever the "2 step operation" is.
There has been no precise clarification of what is the desired logical operation of the circuit.
Somewhere in the discussion, I surmised he wanted to energize a solenoid but was using a light as a substitute for the sake of discussion. After going back to post #5 and rereading it (several timesYou are correct about it not clearly telling us what was wanted. My picture of what was wanted was possibly some kind of indicator such as an alarm or maybe just a "run" indicator that is triggered by either or all of the three machines in some way, then a couple people have mentioned a light for illumination purposes which never crossed my mind when he was describing things.
