larmee
- Jackson, TN 38301
I have an existing switchgear with a spare 350 ampere breaker.
I need to install a 200 ampere disconnect off of this existing gear. The tap is less than 10 feet and I need to know what the options are for using this existing breaker. If I do use the breaker will the disconnect have to be sized to 400 ampere and fused at 200. Would it be more advent adventageous just to tap the bus according to the 10 ft tap rule in 240.21
Thanks
Thanks
