Switching Impedance Grounded system to solidly grounded system
What about having two grounding resistors with isolation switches so that you can select one or the other?
This doesn't get rid of the issue of switching only the grounded conductor.
You would probably need a Make Before Break manual transfer switch. Anything electrical would likely require more maintenance than the resistor itself.
