I have an upcoming project which will replace the existing open loop single motor mechanical belt driven system with two closed loop VFD's. The existing system is subject to belt slip which causes speed matching issues between driven arbors. The project calls for using vector mode VFD's driving each arbor using a shared TAC speed input to both drives. Over all this seems a simple closed loop system.
My concern is precise speed control between the two VFD's. I am also concerned about the use of a single TAC as a speed input to feed both VFD's as each exists in a separate portion of the system. I would appreciate any thoughts, suggestions, or lessons learned regarding speed-matching of multiple drives.
