please see attached image. both transformers are pad mount. as of now i am assuming the utility is grounding their transformer as shown. I am not sure what standard practice is. assuming they do would their be any issues with the grounding as shown on the step up transformer?
my primary concern is the removable bonding strap that comes pre-installed on the transformer as shown. if it is left on will there be any current between the ground rods through the ground? i can't convince myself if there is a complete circuit with voltage or not. a grounded conductor will not be connected between the two transformers.
