T12 bulbs in T8 fixtures saves watts. For real. Constant current circuit
But for everything? Including the lights in the aisle and mezzanine?
Yes.
Many stores have skylights for daylight harvesting and controls that adjust for it. Also dimmed after closing leaving just enough light for the employees to work.
Even without skylights the fixtures near the windows in many new offices will dim or shutdown when the ambient light from the windows is enough.
I have not seen 'dimmed' site lighting yet but I have seen a lot of LED site lighting with two inputs, one for full and one for half brightness. The half level is used off hours for basic security lighting. The last ones I worked with were individually controlled via radio.
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37697
Yes.
This is old or new work? In old work they would just drop 1/2 to 2/3 the circuits for night work.
Makes sense and thank you for the link. :)
It does, otherwise why are so many switching to LED? No matter what, LED will always draw less power over all compared to other lighting technologies like linear fluorescent and HID.
No, it doesn't. The statement is like paper cups always have more ounces than anything else.
I agree, but its up to the user to decide. The beauty of LED is that you have choices.
But they're not helping the free decision making. They make it confusing. When we have to compensate something, we say it simply like
conductor derating or altitude compensation. so technical people are lead to believe that it's a feature arising from advancement, not a feature made necessary due to the high decay.
They make it confusing and wash it out as "lumen management" instead of getting to the point that LEDs degrade significantly and require 43% overlighting to maintain the desired light level at the end of life. The excess lighting wastes power so they get around by starting dim and raising output as degradation accumulates. This has been tried with HIDs before with an electronic ballast... costly The lumen loss for fluorescent systems is under 10% and it's not worth the effort for active compensation.
https://www.acuitybrands.com/-/media/Files/Acuity/Brands/Controls/nLight/nLight Training Overview090215.pdf
They don't explain right to the point the reason for it. LEDs have more output loss than other technologies and maintaining the same output for a long period requires boosting power consumption overcome the LED decay.
http://gothamlighting.acuitybrands....or_switch/147250/document/nio-ledg-lc_pdf.pdf
In some of their later document, you correctly see it phrased properly "lumen compensation"
Not common MH, formed arc tube PS MH lamps:
I've seen these used in car dealer ships, and despite the light spectrum being far away from genuine sunlight or incandescent, the results are excellent and many prefer it.
You must mean ceramic metal halide. They're not spikey as the graph you posted and i believe you're showing the wrong chart. They have wide emissions extending into deep red and have good color rendition.
We offten do dimming in all those applications. I believe energy code driven.
the ones we dim have dimming leads on the drivers and dim nicely.
Any 0-10v or third leg dimming works great. 0-10v eliminates the instability part, but still have difficulty dealing, because different fixtures respond to voltage slightly differently.
With florescent or HIDs yes in the past we would 'checkerboard' the circuit layout so you could have a reduced lighting level for stocking shelves, cleaning the floors etc. This worked but you end up with very bright spots and very dark spots. To the shelf stockers this is a pain, I have seen some use LED headlamps to help them do their job.
Enter LED, now new work or remodel we add dimming to the lights. Typically set to 80% max during open hours, 30% max when closed.
Strike one for LEDs though, in a few instances the LEDs damaged the potatoes more than the florescent they replaced.
Hmm, like say trying to dim both T8s and T5s HO from one dimmer?
Of course different LED fixtures types will react differently, nothing that would not be overcome by zoning.
Some lamps may not be better than actual sunlight for CRI, but may still be better than "daylight" LEDs or CFLs. Especially where daylight is used just to mean a high color temperature.
mobile
Let me clear it up, It may seem disorienting, but it's realistic! The feature set is unparalleled, but the user-centric metrics and non-complex use is always considered an amazing achievement. The metrics for users are more well-understood if they are not synergistic. The accounting factor is end-to-end. We will envisioneer the capacity of user interfaces to implement. The technology takes the best aspects of Unix and IIS. The ability to target iteravely leads to the capacity to scale wirelessly. The technology takes the best aspects of Perl and XSL. Is it more important for something to be subscriber-defined or to be C2C2B? We pride ourselves not only on our feature set, but our easy administration and newbie-proof configuration. Imagine a combination of Rails and SMIL. We think that most extensible portals use far too much RDF, and not enough SMIL.
Well if I've not understood anything in a long time this was it.
Enter dimming ballast
Corrected for ya :)
Well this supports the possibility of LEDs possibly having different physiological effects than HID of fluorescent to other creatures too.
LED solid state fluorescent lamp and regular fluorescent lamp works very similarly but they use different wavelength light to activate the phosphor. Regular fluorescent lamp generates 254 nm light inside mercury vapor and bombard the phosphor blend coating the inside of glass tube that is opaque to 254nm.
"LED light" uses a narrow spectrum 450nm LED in a fluorescent lamp. This color of LED is a very intense, pure blue when it is not part of a fluorescent lamp.
Solid state fluorescent lamps use a broad spectrum yellow emitting phosphor and allows a portion of unconverted blue light to combine to form a white light through Blue + Yellow = white. So if the 450 nm is very active in supporting photosynthesis, I can see how it causes spurt growth.
The result could very well be different for 405 nm violet LED driven solid state fluorescent lamp.
No, I mean replacing one of the many cans on same dimmer with a comparable product that is available on the market at the time of replacement.
As long as every device within each zone has the same dimming curve.
Give me an example where a LED retrofit will actually end up drawing more power.
I am not denying this is true, but I would imagine over time this issue will be resolved by LED makers. Also, wouldn't dimming like Iwire brought up get around this issue.
But over all, does this boost result in more kwh being consumed over the life of the product compared to florescent and HID over a 100,000 hour period? Yes I know FL and HID do not last that long, but picture a few re-lamps with power still counted.
The ones that went up where exactly these by Venture:
Supposedly the formed arc tube (as claimed by venture) results in longer life and better lumen, CRI, ect. I have to say that despite the waveband, CRI ect these produce some of the best light I have ever seen.
Now, if you mean CMH, I would agree.
My point is that despite CRI, color and waveband some LEDs produce results which are appreciated, even preferred compared to Halogen, Florescent and HID.
Good to know that concept wasn't perfect.
I should probably start a new thread on this... but what do you do with the emergency circuit that come roughly every or 8th fixture? Do you also put those are part a dimming scheme or do you just set them to run at a constant 80%?
I am comparing current technology to current technology. Replacing a T5 system with a lower efficacy LED system results in more power draw unless output is reduced. LED retrofit are all too often not selected by lighting designers. They're selected by ESCO sales reps using current system with existing lamps in as-found conditions vs brand new LED comparison. More often than not, they fail to include the proper margin to maintain required light level after 30% LED decay.
Only partly. You avoid having system starting off overly bright but maintaining the output requires raising the power fed to the LEDs loses their LPW as they decay. What starts off as 10kW needs 14.3kW to maintain as LEDs approach end of life. This means circuit capacity needs to be budgeted at 14.3kW, and predictable kW demand increase over time, so rebates should consider this and not give performance rating as if 10kW is the demand.
There are fluorescent rated to go 80,000 hrs and the phosphors do not degrade over 10%.
Old school mercury vapor fails very similar to LEDs. They have a very long life until the arc can not ignite, but the degradation accumulation continues to degrade the lamp that they get too dim.
The light characters depend on the fill chemistry. I am not sure which fill materials is used in the specific MH you're talking about.
http://download.p4c.philips.com/lfb/c/comf-1408/comf-1408_pss_en_us_001.pdf
This one not only has 90+ CRI, it has a relatively complete spectrum including deep red, violet and 450-500nm gap that solid state fluorescent based LEDs are missing. This kind of MH is one of the closest thing we have to full spectrum source.
http://hid.venturelighting.com/LampsDataSheets/NaturalWhite/72315e.pdf
Even with current technology, does LED not pull less for the same comfortable light levels? Any numbers for this?
I do not doubt this, but isn't it still less then what it is replacing, even at 14.3kw?
True, and then you replace them- when the lights get to dim. I know there were roadways/buildings/parking lots of the past where Westinghouse life guards were being driven decades to the point 1000 watt H36 bulbs where putting out as much light as 100 watt incandescent- but to me that is just bad maintenance. When a mercury vapor bulb hit 24,000 hours, you were supposed to replace it, even though it could technically go for 100,000.
Ok, I guess I under rated that lamp :ashamed1::lol::eek::ashamed1: I always assumed quartz arc tube never had a full spectrum.
But my question to you is do you need full spectrum? For most applications it appears none full spectrum lights get the job done be it retail or office. FWIW before LEDs, florescent and coated MH did a good enough job in retail which also lacked full spectrum- and perhaps by a long shot.
Also- consider this and tell me if you agree. In the 90s I remember most of the big super markets and box stores around me were lit with 400 watt coated probe start M59 MH lamps. These lamps had next to no lumen maintenance, color rendering and CRI got worse as they aged IMO (I remember despite the phosphor literally half would turn pink-eye pink the others dull green)- yet despite these lamps being awful by any of today's standards people got by and they did there job. Then came florescent high bays- F32T8 and then T5- they had superior lumen maintenance and still lasted 24,000 hours if not a bit more. But none the less they are still not full spectrum.
Now we have LEDs. Is it safe to say that most of the LED products are still better than old 400 watt MH lamps when all is said and done?
Talk talk talk talk, all from the office.
Here is the real world
FWIW
When we replace HID or flouresent fixtures with LED the current drops by 1/3 to 1/2 what it was and the lighting levels appear the same.
The current drops, the customer feels it is brighter end of story, well that and no one is specifying other technology right now.
Id argue that in most cases it is brighter, and even when over illuminated to compensate for lumen depreciation (as done with all light sources) the energy savings are still significant.
Corrected for ya :)
Not really.
In my experience most linear florescent dimming installations left customers unhappy.
Short lamp life, unstable operation at low levels etc.
Maybe
The problems are the same for LED vs other lighting technologies, dimming and color are not consistent.
This is an insightful paper to read:
http://cltc.ucdavis.edu/sites/defau...led-linear-retrofit-solutions-alcs-retail.pdf
When evaluating quality of light, glare and shadow formation matters. Many fixtures purposely sends light upward and opts to use parabolic mirror reflector. If these qualities did not matter, fixtures would not waste valuable lumens to massage light quality. Sometimes light that is highly directional and casts a very sharp shadow against the wall is desirable such as security lighting.
You could get a decent light level on a desk surface in middle of the warehouse with a projector beam headlight pointing at the desk from the ceiling. You'll pass the foot candle level on the desk plane, but you will have a strong shadow of anything between the ceiling and the desk and this is not a "high quality light". Granted this is an extreme example, but LED based solutions that claim to improve light level substantially with less lumen output have a tendency to lower quality of light in this manner.
Delivered lumen is all the lumens leaving the luminaire and how the delivered lumens form a particular luminous distribution map (Read that PDF) is optics issue, not LED vs competition. Fixture efficiency relates to lumens that leave the fixture vs lumens that consumed within the fixture.
For general purpose indoor area lighting, indirect,completely non-directional light is often the best quality light. It increases uniformity, reduces glare and you also get a low foot candles per lamp lumen.
-Light meters need to be used correctly. Often, light meter is used pointing straight up without bothering to take vertical foot candle.
One also needs to remember that light meter is not an image forming sensor and it is blind. It sees the world through frosted lens goggles. A large frosted light bulb and a tiny clear bulb with the same lumen output looks the same behind it. If you're looking at them with your eyes normally you can see the tiny bulb is a glare bomb.
Compared to what? You have to think like you're car shopping.
Typical LED scenario
Before: Aging large sedan with a lot of problems.
Considering: Overpriced high mpg hybrid with mandatory for $60,000. Compulsively fully loaded(not available without unwanted bells and whistles...)
(why on the earth did you not consider $30-40K vehicle with features you want as option B and compare value with the first option????)
Standard HID requires cooling down before it can re-start. it takes 5-10 minutes to reach full output. Halls and gyms have a lot of lighting hours in between sessions and reservations. 50 minute session and 10 minute vacancy doesn't allow MH to power cycle. Equipment limitations forces the light to remain lit in between sessions and limits efficiency to 83% in this example. Neither LED nor fluorescent require the lights to remain on. So HID gym lights end up staying on all school hours unless there's about an hour or more of vacancy.
1.) The kWh savings from being able to turn on and off whenever is significant even if lm/W stayed the same.
2.) LEDs are incorrectly credited for savings from this. Facility decision makers are not made ware that *either* LEDs, T5, or T8 hi-bays can take advantage of this savings and convenience. If the only thing they have is a sales pitch on highly expensive LED and made to believe he needs to go LED to do this, he just doesn't know about anything else to compare against the highly expensive LED.
So, you get my point. The cost difference between a 175 and 400W MH isn't much, but LED fixture prices rise proportionately with installed lumen capacity at this caliber of lighting. While probe MH can lose 40% between re-lamp cycles, fluorescent systems only lose 10% and when this feasible alternate can do it with 10% light loss, it's unreasonable to give special lenience for LEDs and allow 30% degradation before reaching end-of-life threshold for applications where 4'x2' fixtures can be used.
There's a big price to pay for allowing this much performance degradation.
1.) Requires at least an additional 43% lumen capacity, or quoting end of life at L90
2.) Adding installed system capacity of 43% plus active degradation compensation(which adds $ $ $) and planned kW growth for that lighting system.
3.) Maintaining efficiency means the fixture would require scheduled cleaning or at the minimum wipe-down. So for cost analysis, it is important to compare the cost of LED cleaning only vs fluorescent remove old lamp, wipe down, then install new lamp.
Also, if the installed price of LED is significantly more than double that of the best T8 or T5 system, it wouldn't be totally unreasonable to consider installing double the quantity of fluorescent fixtures and wire them on controls side so that they only operate in alternating bank A or B pattern to spread the wear across two banks.
CRI is not the "be all". It's the average of deviation distance for eight sample color chips, but these samples do not represent all the colors we can see and it also affects fluorescent secondary emission. Fabric and paper brighteners are deactivated under LED lighting. The missing spectrum between blue and green affects the way some cyan/torquoise printing ink and pigments appear.
The deviation can go either way. Too dull, or too vivid. Ok, so you have four 20" tires. If the actuals are right side at 20.4" and left side at 19.6", the average of deviation from center is 0.4". I think we can see the problem with that. A metric like CRI adds up each deviation and divide by the number of test points. The average of 0.4 and 0.4 is 0.4, or 2% of 20. If they're ALL 20.4", it is still 2% average deviation. This makes either of these examples look equal.
Adding another twist, ordinary light sources except for incandescent are poor in deep red rendition dulls the rendition of vibrant red, such as fruits, vegetables, red meat and blood. This falls outside the measurement scale of ordinary CRI. Broad spectrum fluorescent that extends output into deep red such as cool white deluxe also have phenomenal color rendition. You can not see it by looking at the light, or staring at the wall. Arrange some tomatoes, strawberries and red meat on the counter and switch lamp back and forth between standard 4100K LED or RE841 FL vs CWX and you will see it. Who cares? Those in the business where the appearance of such things influence buying decision certain do. After all, the same shipment looks more fresh and delicious under wide spectrum MH or CWX than general purpose LED/FL.
Yes, but extend that to 60-70,000 hours if they're using extra long life lamps. One of the popular applications for ceramic metal halides are produce department and anywhere else where you need broad spectrum light at higher kelvin that halogen lamps can not make without color filters. When 3,000K does the job such as boutique shops, halogen accent is their go to.
No. Plenty of substandard retrofit products. Retrofits have to operate like a chandelier hung inside an inverted metal bucket. The socket isn't much better than a chandelier chain for conducting heat away from the retrofit lamp. Metal halide lamps have a large outer bulb for ease of handling, but the actual lamp inside is quite small. There are special double ended HID lamps that look like halogen work light lamps. These require very careful handling but allows for better and smaller fixture with a better efficiency since it doesn't have to be built around the huge outer bulb. Both the LED elements and its transistorized ballast are heat sensitive. I don't mean that they can't handle "too hot to touch", but they can't operate at 180C coil temperature like magnetic ballast.
When you can have plenty of space in all directions and access to clearance on all six sides, it's easy to use LEDs with a train track like frame. LEDs mount on the bottom of ties and the space between each tie and generous open air clearance on top gives plenty of airflow through the fixture.
