thewiseguy31
Hi all. Has anyone experienced or have any ideas on what could be causing a large number of T8 LED Utunes to crack? We used a reputable brand to avoid issues to no avail. Some notes:
We installed both bypass and direct wire lamps. Only the bypass lamps are cracking.
All of the cracks are on the same leg of the lamp.....where the power is connected.
We hear tested and the lamps that are cracked are running 14 degrees hotter than the ones that are not. The cracked lamps are at 96 degrees.
I do believe this is a mfg defect possibly due to the frosted coating process but I'm just taking a stab.
Any ideas or experiences?
Thanks in advance!
Thanks in advance!
