JasonCo
- Houston, Texas
[FONT="]A 120/240-volt, 1-ph, 3-wire, 100-A main breaker load center is installed for the service on a barber shop. The “green grounding screw” for this panel was lost so you will have to use a piece of wire instead. The service-entrance conductors are 3 AWG. The minimum size conductor you will install in place of the green screw is ___ AWG.
This is a homework question. I am just trying to seek some help on understanding the terminology of this question. For starters, I'm confused about the scenario of this question. If the ground screw goes missing in a panel, how are you going to use a piece of wire to replace it? Do they mean using a mechanical lug to replace the screw? I don't understand what they are saying to be honest... But I'm assuming this is going to be answered off tables 250.122 or table 250.66.
Table 250.66 is Grounding Electrode conductors and Table 250.122 is Equipment Grounding Conductors for Grounding Raceway and Equipment.
Unsure what "wire" they are referring to... Personally I have never used a green screw in a panel, so I have no personal experience with this question.
[/FONT]
[FONT="][/FONT]
[/FONT]
[FONT="][/FONT]
