Don Gorham
What is the reason the Mike Holt DVD series uses the 90deg c column for some wire ampacitys but then uses the 75deg c column for other ampacitys? I understand the 75deg c correlates to OCPD terminal ratings as the industry standard. During temp corrections are you starting with the 90deg c and then if the corrected temp is below the 75deg c use that ampacity? I just need to understand the code explanation.
