ptonsparky said:Give this man a prize!!
Should have known Iowa would come so close. You are scary.
It is on a dairy and this is supposed to block the ground currents that were detected by "witching". Have to admit his rods did not react after this was installed. The - is connected to the GEC with the + to the antenna. The photo cell and contactors reverse the polarity at dawn/dusk.
The battery will not need charging because the protons and electrons will keep it charged. I forget how, it was over my head. Maybe someone can explain it to me.
This is supposed to raise milk production within 24 to 48 hours.
Only because I've seen a similar set up not too far from here. Only it actually was to capture & use stray voltage. #10 wire was stapled to the top of wood fence posts along a path parallel to some 45kv lines, and the transformer was able to convert the stored voltage of the #10 down to 240volts. Go through a switch, two 120v bulbs.... free lights!
I'll contact you on what I want to have you send me for my prize....
