It does comply but you are free to disagree. It gives me a useful and accurate number with documentation of the work that was done. I would say it shows legally diligent professional work. I would take it to the State Board and say the numbers are correct within the accuracy of the method used, that is, accurate enough to determine good from bad. When you get the spot on the State Board, you may tell me I am wrong and you are right
A data center is baseload. There is very little change up or down in the load. The load that is short cycling is a candidate for investigation. It can be improved.
