I use the cord for my Ideal 61-165:
"Cheater plug" would have worked just as easily, as the previous post says..
much safer
But you can't clip on your voltmeter meter to the wires.
much safer
much safer
But you can't clip on your voltmeter meter to the wires.![]()
But it does not give you equally convenient access to the ground pin.![]()
The problem with any of these safe workarounds (especially the line splitter pictured) is that the newest generation of probes come with insulated tips which make it especially hard to insert them into any kind of device in North America and impossible to use with the test holes in line splitters.
Insulated tip---sounds kind of counterproductive in a situation where conductivity is important![]()
Which means more people will be breaking out adapters of some sort that subject them to more exposure so that they can get a reading:roll:I know, my badWhat I'm referring to is that the newest standards for test leads for electrical testing require a max 4mm exposed probe tip. Many testers are now sold with these. Some companies have a retractable design, but others include test leads with permanently insulated tips with only 4mm exposed. It's impossible to test a North American receptacle with these probes, tamper resistant or not.
What we need is a plug block with rotating prongs (so you can set it for 15A or 20A 120V or 240V) and three jacks to plug DMM leads into. In fact, I might make something like thatIt won't have the rotating prongs, but oh well.
