finster1
- New Jersey
I work in alot of tanning salons and the panels in these always seem to be overloaded by design. The engineer on the last salon said he did the calculations, and with diversity he took into consideration the time to undress the actual time spent tanning the time to redress, and that the bed could only be used 3 times an hour and that is why he could add over 400a of service to these 3ph panels on a 200a main panel. Can anyone explain this to me in english if they understand the Electrical Engineers Explanation for this.I am still confused but all of these tanning salons seem to have the same situation. I realize that these beds wont all be on at the same time ,but what if they are. Also in the summer time the nominal voltage of 208v drops and these are all hooked up on buck boost most 3ph with dual transformers they cook breakers frequently. I tryed to explain to the owners that I feel the low incoming is causing the breakers to be overloaded......Lower voltage...higher amperage..in some cases exceeding the rating of the breakers....One particlar chain has these ht60 beds on 70a and in the summer they sit at 73 amps.The ht54 are on 60a and in the summer they sit at 64a. Any explanation or clarifications on my findings appreciated.
Licensed Electrical Contractor NJ
Jimmy P
Jimmy P
