Home has tap directly off meter where main panel and solar sys are connected.
Can a disconnect for EV charger be connected to empty lugs on the tap? Will be protected by OCD, of course.
I'm concerned about adding 60a circuit to main (200a) panel because there are already two geothermal systems, water heater, oven, elec clothes dryer as well as 100 sub.
I'm sure this has come up, with all the EV chargers being installed. The tap is already installed when solar was added. I'm assuming I can use the empty lugs.
Thanks! DXCO, Iowa
Thanks! DXCO, Iowa
