beanland
- Vancouver, WA
I had a client raise a question for which I am not sure where to look in the NEC to determine whether it is permissible. This is a tap of service conductors ahead of main disconnect for a PV system (230.82(6)). There are three sets of conductors in parallel. The client asked if they could tap just one of the three, using piercing taps. The piercing taps are adequate and rated for the PV load. But, it seems wrong to tap one of a parallel set of conductors. Does anyone have an NEC citation indicating this is acceptable or unacceptable.
I have asked them if they can land the PV at the service conductor terminals rather than tap cable itself and am waiting to hear the reply. It may also be feasible to add a breaker to the main panel for the PV. But, an alternate solution is not what I am seeking, I am seeking an NEC citation relating to the original request.
Thanks.
Thanks.
