Alwayslearningelec
- NJ
- Estimator
Installing a small new service.
Where they show to make the tap( between service end box and disconnect section I'd assume there is no existing conduit here as it all one switchboard with service end box attached. Is it even possible to price this tap without knowing the existing conductors? That aside what material would you use to perform the tap? This tap wouldn't be a type that "clamps/bites" onto the existing conductors, correct? Cutting them and installing some sort of tap block would be required? Thank you.
