Oakey
- New Jersey
I am guilty of not getting this done...I just made copies of the form and will do so now. I dunno how this got away from me
Oakey said:Hi guys, I am doing a federal pacific rip out and replace for a home, same amperage, updating grounds, reusing service cable and meter, etc..Would this be considered an nontaxable upgrade or a taxable repair.Thx for any help.
The loadcenter replacement would be taxable, next time if it's a 100A loadcenter, use a CHCH 30 space Loadcenter, then it is considered an improvement, the grounding updating would be an improvement.
You should be filling out the form, signing your name in the "contractor's certification" box and mailing it with your invoices. Have your customer sign it and mail back the original with their payment (they may want to make copies for their own records). These ST-8's are for your records only in case the state decides to audit you.kmc said:can some one clarify when my customers and I should be filling out a st-8 form?
No. Only for those jobs that are considered capital improvements. For example, if you upgrade the electrical service to a residence that improves the value of the house and as such is considered a capital improvement (ST-8 form). If you go to a house to replace a defective switch or receptacle that is taxable. You charge for the device (no additional tax) and add (7%) tax on your hourly labor.kmc said:Should I be doing this here in nj for all of my electrical work?
infinity said:How would the replacement of a FPE panel not be a capital improvement? It could keep the place from burning down.
I'll venture a big YES ~ Permit required.Oakey said:I was wondering ,If a EC replaces a main panel with the same size and amperage (swap) are they required to get a permit for the repair?
Below is a list of projects for which a permit is NOT required. If your project does not appear on the list below, please call the Building Department above to see if you need a permit.
Electrical Permits
* Replacement of any receptacle, switch or lighting fixture rated at 20 amps or less.
* Replacement of receptacles where Ground fault receptacle is required, must be done with a permit.
* Repairs to doorbells, communication systems and motor operated devices.
* Communication wiring in single family residences.
* Replacement of domestic dishwashers
* Replacement of range hoods in single family dwellings.
Just curious, how did the State come to audit you ? Was it arbitrary or did you do something to make their s--tlist ? Once you're on that list you don't get off for about 3 years.satcom said:New Jersey is now checking tax records back 10 years, looking for the slighest mistake, or errors in records, if anyone would question that, just PM me and your welcome to look at the penalty payments, and notices we get, just be one day late on filing a return and your looking at $100 penalty, they just increased the penalty amounts. They are out for blood the way it looks.
If you merely replaced the circuit breakers that would not be considered a capital improvement. However, replacing the entire breaker panel with a new one (including new breakers) improves the value of the house even though you did not increase the size of the service.oakey said:I was wondering ,If a EC replaces a main panel with the same size and amperage (swap) are they required to get a permit for the repair? I have a customer with a rusty panel who failed the home inspection.
