technical literature woodscrews
If you haven't used the square drive screws I think that you will like them. Due to the simple design of the square slot the bit is less likey to slip and spin up as the phillips are prone to do. Also, thay are fairly commonly available and the bits are reasonably priced similar to the phillips bits.
