What code section says this? Is it covered in the NESC? The conductor in question is outside the scope of the NEC per 90.2(B)(4).The same applies to the communications companies when they contact a building. The point of contact is covered by the NEC and the building Code.
,and desirable. We want the various communications companies to interconnect their grounding systems with the power grounding system. Putting network protectors or anything else on the conduit is not a problem, attaching their service drop is a problem.Using a metallic service conduit as a telephone ground is legal
