starsandstripes
- SE Michigan
I am unsure about a couple things on a temp. service. The 100 amp outdoor panel is fed from 100 amp overhead meter socket with #2 Al SEU. It is only a six space panel so I do not need a disconnect or main breaker, right? I am using four spaces to feed four 20 amp gfci duplex receptacles.
Can I bug onto the utility pole ground wire? ( the service is mounted on the pole). I've seen utilities do this in the past.
