Temperature of wire
The 100' has more voltage drop and more resistance.
The 100' is my answer.
Don't forget that the question supposed a constant current source. Heat dissipation per unit length will be pretty much the same.
exactly. J per inch is ez to calc, getting the temp is a pita. temp of the wire and insualtion is highly dependent on what the "heatsink" around it looks like, which is not ez to define. i had already posted some real experimental data, which at the end failed at some time t into the experiment because the temp of the wire got hot enough to melt the rigid foam insulation sandwich and my thermo couples began to read wrong temp.
@OP - lookup my posts of that experiment on MHF, you can then create your own experiment to see how your configuration gets hot.
pre-experiment you can use:
The Neher–McGrath paper summarized years of research into analytical treatment of the practical problem of heat transfer from power cables. The methods described included all the heat generation mechanisms from a power cable (conductor loss, dielectric loss and shield loss).
their write-up covers some common scenarios and from my own testing is rather accurate.
