Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
How would I determine SOOW cord temperature per rated amperes?
I know the #2 AWG SOOW is rated between 80 to 95 amperes before temp correction derating and conductor bundling and our SOOW insulation is rated 90 degrees at these ampacities.
However, as boss wants to use SOOW as a feeder from 100 amp breaker main, according to code I must terminate on what the final breaker is rated for, whether it’s rated 60 degrees or 75 degrees Celsius or 60 degrees when circuit is 100 amperes or less.
This means I must use a larger size conductor to dissipate heat for 60 to 70 degrees.
Although SOOW doesn’t appear to go beyond 95 amperes how would I determine the right size SOOW conductor for a specific ampacity at either a 60 degree or 75 degree rating as I would with standard wire such as THHN per NEC table 310.16? Thanks
