I have seen many opinions on this subject, and I am just looking for a general consensus.
Firstly: Which temperature do you use when calculating the amount of modules allowed in a string? Typically I use the equation with the module temperature coefficient and I grab my maximum temperature from the ASHRAE location nearest the site and use the extreme annual mean minimum dry-bulb temperature.
Second: When derating cables run in the middle of the array, what temperature is used? I have typically gone with the extreme annual dry-bulb maximum for n=20 years or 50 years. I have also been advised to add a 10 degree Celcius adder to this temp. to account for the heating of the modules themselves affecting the cable temp.
I'll be glad to hear any thoughts!
