- New Jersey
- Journeyman Electrician
GalwayElectric said:NYC all temp wiring is done with 12/3 Rx. There is no pipe at all.
No outlet drops are GFCI protected but all trades do (or should) use GFCI between the drop and the extention cord.
It would say some use 12/3 but not all. In the past I have seen many jobs where 12/4 was used. Each temp drop circuit had a GFCI CB in the panel. Typically they used the red/white circuit for lighting, which matched the leads on the socket and black/blue for the GFCI CB. Strange seeing the blue conductors all terminated on the neutral of the GFCI CB's but this is a common NYC installation and IMO a dangerous one.
