- Massachusetts
If you install UF then it will fall under the NEC. Stringing extension cords from the temp service falls under OSHA rules. I believe(don't quote me on this) that according to OSHA rules, extension cords are not supposed to be run directly on the ground because of a trip hazard. Any site I've been on the carpenters build stands to keep the cords elevated to a certain height above grade.
OSHA rules apply to all wiring employees are exposed to, temporary or permanent. Both OSHA and NEC allow cords on the ground.
NEC article 590 applies to temp wiring
