That Man
- California, United States
- Electrical Designer
For the past several years, I've been designing electrical systems that are utilizing MC cable more and more.  Every so often, it becomes necessary to transition from MC cable to conduit, like when an instrument of light is directly mounted to a conduit.  Up to now, I have simply been specifying a TMC connector terminating to a straight coupling.  I have misgivings about this, since there is no way to add the backing nut, but I think this might be alleviated by the threads of the coupling itself.  I would like to stop guessing.
Is it technically possible to terminate MC cable to a rigid conduit coupling via a TMC connector, and run the unarmored conductors in a conduit for an arbitrary distance?
Is it allowed in the code?
Can such a connection be buried? This is the problem I'm facing at the moment, as we are specifying concrete and steel light poles for a project, and I don't want to embed the cable in the foundation, but terminate the MC cable at an underground conduit that runs through the light pole foundation, and run the conductors through the conduit. See attached image. It shrinks down too much, so you can't read it, but the blue lines are MC cables. They terminate at conduits with TMC connectors, and the conductors (red) run in the conduits to the inside of the light pole.
It works in my mind, but I don't actually install things, I just create drawings, and the construction folks don't provide feedback. I can't find any direct reference in any documentation (NEC, manufacturer info, internet search), but there might be an indirect reference, like if terminating to a conduit counts as a junction box, or something similar. I rely on Mike Holt forums for guidance on so many problems like this. I appreciate the help.
