Questions like this has been asked on this forum before and I have read through some of them but not understood the details.
In my apartement the incoming tv/internet signal first goes through a 2 way splitter. One of the taps of this is currently open. The other one is connected to a 75 ohms cable that goes to a coax outlet that is terminated with a 75 ohms. My set top box is connected this outlet and it both has a hdmi output for tv and act as a wifi router.
The general advice seems to be this: terminate the unused port with a 75 ohms. This will prevent problems for other people in my apartement building.
What I am wondering then is:
1. will not terminating the unused port reduce the power of the signal at my outlet?
2. how bad could the problems caused by not terminating the port be?
Regarding 1: I would think that if 4mW goes into the splitter each port receives almost 2mW. The unterminated ports effect is completely reflected and divided by the other port and the incoming coax. Therefore 1mW of the reflected energy should go into the active port? If I calculate the reflection coefficient of the open port I get: R=(inf - 75)/(inf + 75) = 1. Does this not mean that the reflected signal has the same phase as the incoming signal and therefore will interfere constructively with the incoming signal? Therefore I should get 3mW of signal power with an open port vs only 2mW with a terminated port?
Regarding 2: There are 16 apartements in my building. I imagine the signal comes into the building goes trough an amplifier followed by a 16 way splitter before it gets into my apartement. The 1mW of reflected power from my example above that goes back to the 16 way splitter would then be split into 16. Therefore my neighbour would get a slightly delayed ghost signal 1/64 of the power of the original signal. Does this matter? Can this do any harm?
Thanks in advance for any answers!
