So, just to be sure I understand how it all goes together.
1. There is a circuit run from the service panel to the connector location. This could be a standard 15 amp wall outlet at 120VAC to maybe 100 amps at 240VAC.
2. When you install the connector, you set the dip switch and rotary switch on it to match the power available.
3. The car actually control the charging, based on the info it reads from the connector.
If I have that right, then the critical thing is that the breaker at the service panel is sized correctly to protect the conductors going out to the connector. If someone decides to "boost" the charge rate and sets the dial up a notch or three, the car will try to draw accordingly, but the breaker in the panel will likely trip. Often, if the owner doesn't get the message.
I suppose if you wanted to, you could set it up so the breaker and conductors could carry the full breaker rating indefinitely. If you come home regularly with less than 25% charge remaining, you will definitely be charging for more than 3 hours.
