Service limit
Service limit
The fact that you have 200a 240v service to the house doesn't mean you can use all of that thru the Tesla system. Tesla has a circuit limit of 5000watts continuous or 7000w for peaks of less than 10 seconds. What you need to know is how much you are using for existing loads and to do that, get out your last few electric bills, add up the Kwh and average them out to how many Kwh you use in a month, divide by 30 and that's roughly your daily consumption. Ours worked out to around 17kw/day, so for a 24 hours day, our average load is about 710 watts, certainly within Tesla specs. It might shoot up to 5000w when we turn on the electric dryer but it handles it as long as we don't use much else in the house, certainly not the microwave, toaster, coffeepot, hair dryer or other high consumption items. All of those together wouldn't equal 5kw, so if the dryer isn't running, and it only gets used perhaps once or twice a week, the system handles it and the sun recharges the battery, if you do this early enough in the day. According to the Tesla app, our household consumption is more like 13Kwh/day, not 17, as the power company's meter says. I trust the Tesla app to be more accurate...every amp the house uses passes through the gateway,whether it's coming from the panels, the battery or the grid or some combinatgion, and is easy enough to measure.
If your average loads exceed or are near this 5Kw limit, you'll might consider installing breakers to kill certain circuits when you are using the Tesla as a grid backup, or just don't turn certain stuff on, or shut if off if it's something like an electric water heater which you have almost no control over when it turns on and off. A/C on a Tesla system is pretty iffy...better be an efficient inverter split system and don't run it all day.
Good luck
