To answer the second part of your question 250.66(A) says that you dont ever have to have larger than a 6awg copper grounding electrode conductor. Youd have to look at table 250.66 to see if you could go smaller.Hi on a grounding electrode rod commonly adjacent ti residential breaker panels, what is the name of the tool which can test resistance between Earth and ground rod And how is it done?
NEC Allows exemption of one electrode conductor is resistance is “25 ohms or less?”
Thanks
Also to the best of my memory I calculated grounding conductor to be 6 AWG based (Or 8???) on Largest conductor (feeder?) being less than 1/0
Is this right. Thanks
