Hi All -
I am replacing an outlet that is only fed by ungrounded wire. As read all over this site and the web, I am attempting to replace it with a GFCI outlet. The test button on the GFCI works correctly, but I have a tester that is supposed to simulate a fault and trip the GFCI, but it is not doing so. Is this to be expected without the ground connected? Is it possible my tester is not simulating the fault properly? I have tried this with another GFCI outlet to verify the outlet is not at fault.
Thanks -
Al
Thanks -
Al
