LarryFine
- Henrico County, VA
- Electrical Contractor
Same here, plus down-stream receptacles fed from GFCI load-side terminals can only be tested with a plug-in tester (or a wiggie or other 'artificial' hot-to-ground load.)eprice said:Now that statement brings out my skeptical nature. As I understand it, the test button shunts a small current to the line side grounded conductor, while a plug in tester shunts roughly the same small current to the equipment grounding conductor. The imbalance seen by the sensing coil should be roughly the same by either method. I can't see how a plug in tester could cause premature failing of the device any more than use of the test button. :roll:
