electricalperson
- massachusetts
i dont use averging meters just true RMS. im thinking of getting a simpson multimeter soon. used one in trade school and really enjoyed using one.langjahr@comcast.net said:You should know
-Some meters respond to average values but display a calculated RMS value, while others respond to RMS and display it.
-That a waveform with high voltage spikes on it may be ruining your meter even though the meter shows a value well within range.
-A meter doesn't care what it's looking at, it will display a value. If it's looking at a sine wave, that value has a lot of meaning. Otherwise, . . .?
-The instrument that does the least interpretation for the user (a scope) may also be the hardest to use.
-Instruments have limited bandwidths, so if you looking for the short-duration spike that's causing your problem, you may not always see it.
