Steven B
- Clarksburg, MD
I am currently working in an older home with ungrounded 2 wire circuits. I have installed a GFCI receptacle to protect 3 wire ungrounded receptacles downstream. I know that a plug tester with a GFCI test button will not trip the GFCI receptacle but I assumed I could test the downstream receptacles by shorting the hot side of the receptacle to a nearby piece of grounded metal. I thought that it would simply trip the upstream GFCI well before the breaker would trip. To my suprise, I got a nice flash and the breaker tripped. Aside from any criticisms of my test methods, can anyone tell me why the breaker tripped instead of the GFCI? I am pretty sure that everything is connected properly. The test button on the GFCI works and kills power to the downstream receptacles.
Thanks for any help.
